RC Monster
2S - 4800KV Mesuda Motor Too Much For CRT.5???
MiamizFinest
MiamizFinest's Avatar
2S - 4800KV Mesuda Motor Too Much For CRT.5??? - 01.10.2010, 12:24 AM
Ive done a little reading and im seeing you guys are using alot lower KV's than what i was planning on using i have a spare 4800KV and MM esc laying around my closet i was serously thinking about converting my CRT.5 over to brushless I KNOW 3S is WAY TOO MUCH for the track on this motor but will 2S be OK do you guys forsee me having temp issues?
GO-RIDE.com
01.10.2010, 01:55 AM
A few guys have used that motor on 2S in a CRT.5 and it worked great. I use the Medusa 50x3300 on 3S in my 1/10 truck sized CRT.5 and it is ballistic.
E-8ight - Tekin RX8 2000kv/4S
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.10.2010, 02:31 AM
I use the Medusa 36-50-4800 and 2s lipo in my CRT.5 and it's a great combo. I have geared it anywhere from about 28-40MPH and never had any temp issues. I run a MM esc with no mods
MiamizFinest
01.10.2010, 02:33 AM
perfect THANK YOU!!
01.10.2010, 02:35 AM
Sounds like a good combo to me. I ran a 4500kv neu motor on 2s in the mini hyper ste and it did very well. Similar sized truck. Plus 2s lipo will help keep the weight down!
rexasso
01.10.2010, 04:21 AM
TO know if the setup is OK :
first never exceed 50.000 rpm : so 4800 * 7.4 = 35000 rpm. You are far from 50000 (even at the begining of the run while lipo deliver more or less 8V = 40000rpm)
Now for you truck : you just have to adjust pignon / spur ratio tohave you motor not to hot (never exceed 60/65 in Clesius)
RC Monster
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
