RC Monster
Crt.5 upgrades? First bash and first damage...
Bazzokajoe
Crt.5 upgrades? First bash and first damage... - 01.22.2011, 04:21 AM
Right...
Damage was done during some small jumps...
http://tinypic.com/r/2805ppl/7
I know the second picture is my fault... should have set the servo saver more loosely...
I have just replaced with the stock parts, and have cnc rear brace coming.
I am looking to bash this pretty hard so i was wondering what hop ups your using and what you break often...
Thanks alot guys, any help is appreciated :)
brainanator
brainanator's Avatar
01.22.2011, 03:52 PM
you did that on those tiny jumps?!
What conversion are you running? Mike's extended chassis (doesn't look like it)?
Bazzokajoe
01.23.2011, 05:07 AM
i thought the same.. was expecting it to be much tougher... Had been jumping it for a while before the camera came out but i still wouldnt expect so much damage...
was pretty cold tho :P
the servo saver spring will be replaced with a harder one and wound the hole way out so it absorbs more of the impact.
Rear bent driveshaft will be replaced and the rear brace swapped out for a cnc one...
No chassis kit, just the SCRT10 Motor mount and a cheap battery tray... otherwise all stock
was planning on switching to mikes scrt10 chassis kit at some point, and running with a truck body... like an extended hyper10tt.... or would the extended chassis kit work better for me?
RC Monster
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
