RC Monster
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
03.30.2011, 01:24 PM
Cool man! I can't wait until you get some behind-the-wheel feedback. When you lift up with your hand on one wheel does the other side come up aswell? Does it move any? Mine moves slightly. I wonder if the wire is too stiff on mine. I'm not sure.
My Maxx has been at home for several months while I've been away at school. I can't wait to run it on the upcoming spring break. I still have to install the front sway bar.
-Zack
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
03.30.2011, 02:05 PM
-Zack
Hey Zack... the mechanics of the layout works well... but i think the bars are a little thin to make good influence with the heavy springs installed on the shocks...
for 1" of movement I make with one arm, I get about 1/4" of travel on the other... I am currently using 2.5mm and 2.7mm bars for now... I am going to do a search
for some 3mm or 3.5mm spring steel to see if the movement can be increased further...
Regarding your setup... I did try a similar orientation to yours, but i noticed that the angle of the bar did not allow for enough leverage... The bar had little movement...
Did you try to see what kind of movement you would get with the shocks off? I looked at a few setups from different makes and they all seem to have the same orientation,
perpendicular to the suspension arm...
I'll see if i can get the truck together this week for testing...
Alien
Kcaz25
Kcaz25's Avatar
03.30.2011, 03:26 PM
When comparing my setup to my cousins Losi 8t my bars actually have more influence. I can't remember if I've tested with the shocks off. Remember mine is attached to the lower arm. I'll have to get some better shots when I install the front as well. Long live the Maxx! Right? I love it. lol This has gotten me anxious to get my hands back on it.
ANGRY-ALIEN
03.30.2011, 04:42 PM
I see... I actually looked back at your post with bar installed... I am not sure why you are getting this problem then... btw, how thick is your sway bar?
looks beefier than mine... I am more likely needing something with that diameter...
Long live the MAXX in deed... I have seen recent posts on this forum that people are still investing in them... I have enjoyed this truck for so
many years and I am sure I will continue to...
Alien
Maxxrickard
Maxxrickard's Avatar
04.03.2011, 04:54 AM
Where can I buy a piece of CF? Can I cut and drill just like I don in a piece of wood or alu?
SWEDISH FLM MAXX 5s MMM2200
ANGRY-ALIEN
04.03.2011, 02:13 PM
[/quote]
Carbon Fiber is available from numerous suppliers... I got mine from ebay...
The bits below are built specifically for carbon fiber:
"Milling cutter for carbon fiber"
"Solid Carbide Carbon Graphite Cutter"
Alien
ANGRY-ALIEN
06.13.2012, 12:02 PM
Hmmmm... it's been some time since i last made an update to this thread...
well the truck still runs, but it's not as frisky as it use to be... the upper deck plate was broken and there is not a lot of strength anymore, so that has forced me to squeeze a little less on the throttle...
I will be making some changes/improvements with the chassis design soon... I will be adding a new steering servo (Airtronics 94780m 423 Oz) to coup with the weight and torque this thing puts
out... I'll be changing the 23mm hex stuff to 17s... Hong Nor Shafts and the some Dace 17mm adapters will be installed... I'll also be modifying RPM knuckles to facilitate 16mm bearings...
I guess I'll be posting up the rebuild soon enough...
Alien
Kcaz25
Kcaz25's Avatar
06.13.2012, 06:01 PM
I'm sorry to hear about the busted upper deck. I'm glad you are going to heavier stub axles !
Tell us more about this Hong Nor shafts!
-Zack
gumleguf
gumleguf's Avatar
05.23.2013, 05:25 AM
This is one of my favorite DIY projects ever(!) so I wanted to check if you have any updates on the truck?
RC toy
Got Brushes? NOT
RC toy's Avatar
05.23.2013, 07:43 AM
So is mine! Looking forward to see the RPM updates and axles. One of the prettiest trucks out there Alien!
  Send a message via Skype™ to RC toy
ANGRY-ALIEN
05.23.2013, 10:21 AM
Wow... That's a serious compliment coming from you sir... considering the projects you have had... Thanks!... well... the project is stalled for a little bit...
been gathering parts, so hopefully I can make the mods and updates in short order...
Thanks! .. The RPM mod worked to some extent... Two issues though... One - The RPMs though big and sturdy, did not have a enough meat for me to remove
and fit the 16mm bearings... Two - The truck is one fat beast... heavy and brutal... I saw a big challenge for the RPMs holding up under pressure... There was a
whole lot of movement/play with hub and it got real wobbly... I have moved on with another 'project' to fit OFNA knuckles... This requires me milling down and
rethreading the Pillow screws to fit into the arms... I got the parts, but no time to start it... Hmmm... I will make an update as soon as I can...
Thanks for the interest guys
Alien
RC toy
Got Brushes? NOT
RC toy's Avatar
05.24.2013, 06:38 AM
I think I have seen an MBX6 hubs fit on en Emaxx. It involved serious modifications though...
ANGRY-ALIEN
05.24.2013, 05:57 PM
It does require some work to have these pillows 'work' with the UE widetracks... My 'milling' method will include a file, a hand drill, a 2.5 mm allen key
and some serious patience ... I just need to get started...
Alien
coolhandcountry
coolhandcountry's Avatar
05.25.2013, 09:03 PM
What is left to do on this project now?
Peace!
Country
Help support the
Rc-Monster
Buy here
WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.24.2013, 12:17 PM
Wow I can't believe I never found or came across this thread. I love builds with custom made parts! Well done man! Props to you for all your time and hard work in getting this thing built. I would love to see some fresh updates
-Travis
Adults are just kids, with money.
Common sense, is not so common.
Tags
cc 1520 1y, flm carbon fiber chassis, hacker c50 10xl, ofna spider, ue widetrac
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
