RC Monster
Anyone available for some lipo work?
kulangflow
Never Fast Enough
kulangflow's Avatar
Anyone available for some lipo work? - 10.18.2011, 02:12 PM
I have soldered several NiMH, NiCd, and LiPO batteries over the years, but I never seem to have much luck with the Aluminum tabs on NeuEnergy packs. I've tried using the recommended solder and paste for Aluminum, but apparently I'm just not very good at it.
Anyway, I am looking for someone willing to convert my 4s NeuEnergy 5500 pack into two 2s 5500 packs.
I will provide the new 2s balance taps, new pack wires, connectors, and shrink wrap. You'll pretty much just need to do the actual soldering if you happen to have the knack for it.
I'll pay for shipping each way and just let me know how much you need for your labor.
Let me know if you're interested.
Thanks!
Brian
scarletboa
scarletboa's Avatar
10.18.2011, 02:25 PM
well, it sounds like you have the skills to solder the packs yourself. you might just need a different soldering iron/gun.
i have found that in my experience, it is easier to solder on aluminum with a gun style soldering rig. all you have to do is hold the trigger down and preheat the tip until it starts turning red, holds it a few seconds longer, and then solder the joint. aluminum soldering requires a higher temperature, which can be difficult with a iron/pen style soldering rig. i personally use a radioshack 230/150w gun. i was advised against it, but i prefer it over my weller 80w iron. with the ability to preheat the gun as much as i need, i can solder larger joints faster and with much more ease.
also, make sure you have aluminum specific solder and zinc flux. if you do not properly flux the joint and use the appropriate solder, it will not stick. instead of a light application of flux usually used for wires, etc, aluminum tabs need a good brushing with flux. my advice would be to take a toothbrush and lightly scrub the flux onto the tabs before joining them.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.18.2011, 04:28 PM
I can do it, have worked on a few Neu packs. However if you already have the stuff why not just do it yourself and save the money. PM me if you decide to have someone do it and want me to do it.
kulangflow
Never Fast Enough
kulangflow's Avatar
10.18.2011, 04:36 PM
I've tried and failed several times with other aluminum tab cells, but I may give it another go with a bigger iron like scarletboa suggested. I've been using a Hakko 936, but I'll try my Dad's gun-style big iron.
I ended up tossing the aluminum solder and zinc flux. Where do you guys purchase yours?
Thanks for the advice, btw.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.18.2011, 11:32 PM
I honestly can't remember where I bought it, I looked through Linc's thread on lipo repairs and he had a link where he was getting it from
brushlessboy16
brushlessboy16's Avatar
10.19.2011, 09:50 AM
Cheapbatterypacks.com
:) zinc flux and aluminum solder
  Send a message via Yahoo to brushlessboy16 Send a message via AIM to brushlessboy16 Send a message via MSN to brushlessboy16 Send a message via Skype™ to brushlessboy16
RC Monster
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
