Seems pretty quick to me. Given your description before I thought it would be much slower. Still have some concern about that rollout though. Going to need a motor with more torque to have a cool running setup. Also maybe look at lower kv, higher voltage.
If you bought a controller for 8s, I think this motor would work very well in your conversion. (If it fits) Turnigy Aerodrive XP 63-64 230kV The motor shaft is 10mm so you would probably need to turn it down, but otherwise it should have plenty of torque. Same RPM, same rollout, same speed- higher voltage, more torque, greater efficiency.
A much larger and lower kv motor should help. But I think as with my LST its to heavy. The best setup is some gear reduction. You can still use a outrunner but it just needs to be geared down. I think I'm going to put a center diff in my lst.
How would you be able to mount the output shaft on the back of this motor?
I would be interested to do a savage 8s outrunner with this and the HC 8s-12s
i talked to steve neu and he said it would be no problem making a 1900 series inrunner with shaft extending through both ends in 8 mm
i'm planning a direct drive myself and my calculations are that about 200 kv motor is needed for 6s but lower kv for higher s count. these calculations are for bullet proof diff ratio and 7 inch tires.
