RC Monster
radioman193
radioman193's Avatar
05.18.2011, 08:10 AM
Originally Posted by brainanator View Post
built an autopilot for one of my professors (college credit for playing with an RC plane FTW!) and it had all the gyros, bells, pitot tubes, gps, and whistles. Pretty sweet stuff.
yep it is kind of cool to do things that most people would not do.
and don't think you should do
or do things people say will not work.
that is how we learn what can and can not be done
and to find a way that it Can be done .
just remember this most of the inventions we use on a day to day basis were a mistake
or a failed attempt at something other than what they were trying for
Or Got ridiculed for doing what thay felt was a good thing and would work.
If man went by the "book" and Never tired to do something they were told would not work or would be useless ..... remember these
The horseless carriage / Automobile
flying machine / the Airplane
The Auto gyro / Helicopter
Penicillin
and the list goes on for a Long ways
"most" of the people that tell you things like this have No first hand experience on the matter
they have only hear say then try to preach it like its gospel fact.
Just Fix It !!!
I have been into electronics for 30+ years
and am a licensed Electronics Technician for over 26 years now.
  Send a message via AIM to radioman193
mothman
05.19.2011, 02:16 PM
Hey radioman, glad to see this thread. I have been wanting to put a gyro on my savage. I was thinking to put this on my truck since I can get one for quite cheap ~$30
http://www3.towerhobbies.com/cgi-bin...?&I=LXVA42&P=7.
I prefer the reliability of futaba as compared to esky. Do you think it will work?
radioman193
05.19.2011, 04:59 PM
Cool
Im not shure just what the benefit would be in a 4x4 MT as i have not tryed it
in Mine yet..
My Main concern is how that gyro would hold up in a MT if you start Bashing with it ..
and my other concern is this...
"This gyro performs best when used with non-Digital servos."
and cool it only needs your Steering Ch1 to work you will not be able to control
the Gyro on the "fly" from your TX but will work.
$30 looks to be a good deal i would say what the hey and give it a try .....
just Remember this .
Never get them wet
and Gyros Don't like vibration and strong Shock.
you can help by usen epoxi on it
just coat the boards inside it ....
after testing it out and getting it all setup and adjusted you then can coat EVERYTHING on the Gyro cover the Gain control and all ....
just dont cover the FWD / REV or your AVCS switches
Even if you dont get it wet the Epoxi will Aid in maken it more Solid
and help protect it from vibration and shock ....
Just remember these Gyros were Built for helicopters not our land based Rc's so
they were not built to take alot of vibration and strong Shock or water.
The Epoxi is a Good Quick Solid Fix for this ....
well I will shut up for now just let me know what you have done and how it works for you.
Thanks.
Just Fix It !!!
mothman
05.20.2011, 12:51 AM
Thanks for the reply radioman. I was wondering if normal piezoelectric like this http://www3.towerhobbies.com/cgi-bin...?&I=LXKTT2&P=7
would be better for car use? The one that I showed uses electronic sensor. Which one do you think has higher reliability?
I don't really bash my MT, just want something to help with my bad driving skill.
radioman193
05.20.2011, 01:10 AM
do you have a 2Ch or 3Ch radio system?
if you have a 3Ch just get the one like i have
a dude on the Blitz forum just got His today
walker
Member Join Date: Feb 2011
Well I got my gyro in and all I can say sweeeeeeeet it is way to much fun I wish I would have done this a long time ago.
problem is I can not hardly drive with out it now If I turn it off I'am all over the place owell I guess I well have to put one in all my rc's like I said it is way to cool .Thanks radioman for the idea .
thanks for all the info an help made it real easy to hook up.
This is the one i have and use.
ek2-0704B look here you can get it for like $20
http://shop.ebay.com/i.html?_from=R4...All-Categories
but if you have only a 2Ch
get the first one you posted ...
or the one i posted
ek2-0704 Not the ek2-0704B
Just Fix It !!!
mothman
05.20.2011, 04:33 AM
I have 3 channel radio, futaba 3pm fasst. I know the e-sky works perfectly but I prefer the reliability of futaba stuff and I can get this stuff quite cheap.
radioman193
05.20.2011, 05:08 AM
its your call.....
"reliability" is out the door when used in a land based Car/Truck..
A "out of the package" Gyro will not last long No matter what Name is on the label.
Unless you do something to Make it last.
But get the one you wish to get
I can link you to some that are $200 or more if you wish to have a name brand .
Thay ALL do the same thing.
All i Do know is i have BEAT THE HE!! out of this one with No Glitches or Problems.
good luck to you in what ever one you buy .
Just Fix It !!!
JoFreak
JoFreak's Avatar
05.20.2011, 06:15 PM
Hey radioman, do you think it would be possible to use the gyro to counteract traction rolling?
Mount the gyro vertikaly and set it so it gives a short steering impulse into the direction the truck is leaning into?
So for example, if the chassis leans right, over 30 or something, while steering left, the gyro gives a steering imput to the right until chassis lean is below 30 again?
May lead to a few contacts with the track boundary, but shouldn't be a problem for an SC? Better than rolling over and waiting till someone puts it back on it's wheels.
radioman193
05.20.2011, 08:11 PM
Im not shure Hmmmmm
the guro dont react to a lean ...
it only reacts to a pivot on one axis and cant be set to react at a certain degree
But by what you are asking you can try the Gyro with the Switch in NORMAL
and see what that does
with the gyro set upright "wires up top"
it just might work .
#1 with the switch in normal if you pivot LEFT Gyro would turn the wheels LEFT
#2 with the Switch in REV and pivot LEFT the Gyro would turn the wheels RIGHT
Just Fix It !!!
mothman
05.23.2011, 12:00 PM
Radioman, maybe you should try this on your truck..
http://www.rcgroups.com/forums/showthread.php?t=1427708
radioman193
05.23.2011, 06:25 PM
i dont need that.......
I just need to put like NASCAR Roof Flaps in the roof of my car
to keep the car on the ground.
The wind gets under the Body and i end up with a blow over.
Just Fix It !!!
Semi Pro
Semi Pro's Avatar
05.28.2011, 10:18 PM
so i bought the ek2-0704B but when i set it up with my dx3r in my traxxas rally all i get is a slow flashing led on the gyro, and clue what did wrong? lol, i fallowed your instructions, sorry i haven't tried a gyro on land before and I'm alittle lost
could it be the stock non digital servo thats the issue?
radioman193
05.29.2011, 01:54 AM
I know Nothing about the dx3r Tx
the yellow wire is on Ch3?
and your tx ch3 needs to be on when you turn the rc on.
"For My radio all i needed to do was....
just plug it in to Ch1 on the RX
the yellow wire to Ch3 on the RX
Flip the switch on the Gyro to REV
Turn on the TX
turn on the Rc.. Wait for the Gyro to set its self about 3 seconds"
if the gyro DON'T see a signal on ch3 it will not initialize .
Just Fix It !!!
Semi Pro
Semi Pro's Avatar
05.29.2011, 06:25 PM
well i have tired it with 2 diffrent radios and many diffrent servos, the best i have gotten out of it that been alittle servo flutter then nothing, i think i may have got a bad one
radioman193
05.29.2011, 07:01 PM
so its not dong Nothing like the one in the first part the last video i posted ?
Just Fix It !!!
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
