RC Monster
Servo Question
AP Alex
AP Alex's Avatar
Servo Question - 10.07.2013, 10:28 AM
How do you check if a servo is going bad? It will turn great to the right, but will barely move to the left. Took horn off and same issue.
Thanks for input
10.07.2013, 08:00 PM
Sounds like one of the "axle" (from one of the gear assemblies inside) holes are elongating. Happened to me a while back on a cheap servo that didn't reinforce those plastic areas with some kind of bushing.
Justinbolin
Hugo Stiglitz
10.08.2013, 06:40 AM
I use to burn up servos all the time in my first EMaxx truck that I converted to brushless 6,7 years ago. And I was killing them 2 at a time. I fixed the issue by going with higher end servos.
Not sure what rc your having your servo issues with.
If I knew I'd give you a couple recommendations.
Here's a few things I look for in a servo when I buy one:
-1) More torque then I'll ever need.
-2) Coreless motor.
-3) Steel or titanium gears.
I stopped having servo issues when I dropped a hitec 7995 servo in my truck.
You also want to make sure you have your endpoints set correctly and there's no binding in your steering linkage.
If you have a decent transmitter (not an RTR radio) you should be able to set up your endpoints pretty easily. I think not having my endpoints set properly was why I kept killing servos in my EMaxx.
Justin
[1] Gorillamaxx G4 w/Flexteks
[1] Gorillamaxx G4 w/RacerX
[1] Gorillamaxx G4 w/G3.3
"No one can resist my Schwetty balls"[/b]
  Send a message via Yahoo to Justinbolin
AP Alex
AP Alex's Avatar
10.08.2013, 11:34 AM
I will double check, but I think it is a Hitec high torque servo. That's usually all I use.
RC Monster
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
