RC Monster
9920 Marine
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
9920 Marine - 04.23.2007, 08:44 PM
i saw a nice deal on a bk 9920 marine. Wuts the diff? Would it work on revo? I think i might have fried my 3rd one. It coggs sometime for no reason. Also, theres no brakes, PERIOD. I've been setting my eyes on a nice MM recently though (is 150 for a 7700 system alot?)
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
nativepaul
nativepaul's Avatar
04.24.2007, 08:11 AM
The Bk9920WK is water cooled, has forward , reverse, brakes (but I think its non-proportional), it has water splash protection and it is a lot heavyer but the heat sink and water cooling are both within the heat shrink so it would negate the benifit of the extra heatsink mass and may well run hotter than a car controller with exposed heatsink (unless your thinking of a radiator for it).
Unless you think youve been frying your ESCs from water ingress not heat? in which case a splashproof controller would seem like a very good idea.
Personaly if I fried 3 of the same controllers, there is no way I would buy a 4th.
Is it for your Revo with 9L? Lots of peeps buy the BK for high voltages and the 9L is quite high KV, so may I ask How many volts you are puting into it? With what gearing inc wheels? It could be a very hot setup and you need a big MGM, Schultze, (or MMM when it arives) to cope with the amps, or need to tone it down with gearing.
I think $150 is very good for the MM combo I've seen them around $200 often. Why not get the MM combo for your 1/10th scale and try the MM ESC in your revo, if it works Great. If not you have found out you realy do need a monster ESC for it for a lot less than a new BK woud cost, as CC will fix it for $50 then you can use it again in your 1/10th scale.
nbcaznmaster
04.24.2007, 03:37 PM
What do you mean non-proportional? Splashproof is a very nice looking benifit. The MM combo i mentioend is used.
LSP-R - Picco .26
Nitro Revo - .18tm
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.24.2007, 03:42 PM
on or off, nothing inbetween.
losi 8ight-t
xray xt8
Gustav
Gustav's Avatar
04.24.2007, 03:52 PM
You can get a new MM esc here in the store for $137,or were you planning on using the 7700 motor for something? i don't think you'd get much for a used MM motor so if it's just the esc you're after i'd buy a new one.
Serum
Serum's Avatar
04.24.2007, 03:53 PM
It uses different software than the car escs. you could sent it in to BK to have it reprogrammed.
nbcaznmaster
04.24.2007, 04:56 PM
hmm, its probably not worth it than. I really dont need the motor, but i was thinking about selling it off and maybe getting 60 bux or something
LSP-R - Picco .26
Nitro Revo - .18tm
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
