RC Monster
Will I be OK with a 2S in my CRT.5??
g-townmach
Will I be OK with a 2S in my CRT.5?? - 07.29.2011, 12:20 PM
I plan on changing over to the castle-neu 1415 with MMP soon but if I do so will I still be ok running a 2S?? Have been considering the max-amps 120c 5400. Right now I use a 12t pinion and stock 46t spur.
All out speed is not my main concern. Would like to stick to a 2S instead of going to a 3S due to cost, weight and size.
Just want something quick, fun and with decent runtime.
Any advice is appreciated.
07.29.2011, 12:53 PM
well, the difference in weight from a 2s to a 3s is not that much really...depending on the battery manufacturer. If you are stuck on 2s something like a 1410 would be a better choice IMO. As far as max amps batteries go, you can buy as good batteries for A LOT cheaper other places
sent you a pm as well
brainanator
brainanator's Avatar
07.29.2011, 01:30 PM
I run a 3500Kv Medusa motor with a mamba max ESC on 2S with 17/46 gearing. Motor stays cool, battery stays cool, esc heats up a bit, but not too much.
RC Monster
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
