RC Monster
electric bicycle
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
electric bicycle - 05.31.2009, 11:23 PM
okay guys.... ive been doin some thinkin and i have this crazy idea to "electrify" my bicycle. wat im planning on doin is using the e-revo transmission with the castle 2200 motor and MMM esc. im planning on buying a 6mm pinion to attach to the output on the e-revo transmission. the pinion will make contact with my bicycle tire and will spin it. the drive ratio of the e-revo transmission is 1.83333 rotations of the spur to 1 rotation of the outdrive. and im goin to factor in the pinion/spur ratio and adjust to attain my speed. i am also planning on buying a back pedal bearing so i eliminate brake shoes and the lever. i also have few questions. do you think the 2200 motor will be able to move a 15lb bike and 120lb. person at about 20mph? will the amps be too much. im also wondering if i can lightly press the brakes while riding to utilize the regeberative braking? im also seraching for a device that connects to the MMM wire instead of an rx that can control the speed.
just an idea.... so suggestions are welcome
-mikey09120
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.31.2009, 11:43 PM
There are hundreds of diy electric bike kits out there. One of the good things about electric bikes is that 1000 watts is a lot. The mmm puts out WAYYYYY more then that. Oh Yeah baby,,, yah- trick yaaa.
Look up 1000w currie motor e-bike or something like that on youtube. It's not the best, but here's the first one I found.
http://www.youtube.com/watch?v=TyFYw...eature=related
The easiest way to do it is to get a hub motor kit which comes with everything and is very easy to do. It'll probably be the most reliable way to do it too. If you end up using the mmm, I'd gear for anywhere between 20-30mph depending on the speed and runtime you want.
mikey09120
mikey09120's Avatar
06.01.2009, 12:38 AM
before electronics...
-mikey09120
mikey09120
mikey09120's Avatar
06.01.2009, 12:39 AM
electronics hidden under the seat
an overall picture
pinion will attach to outdrive and will spin the tire and NOT the chain
now i just need to cut a steel plate for the tranny and weld it to the frame
and buy another pinion and grind it a little to stop it from chewing up the tire
still awaiting on 3s 5000mah 30c flightmax lipos to arrivee
-mikey09120
06.01.2009, 12:47 AM
that'll just tear up your tire. Video!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.01.2009, 01:12 AM
Yup!!.. unless you're already moving.. then it might not... If you want to do something like that, buy an outrunner motor with the 12mm shaft..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
mikey09120
mikey09120's Avatar
haha. yah. im gonna have to grind the pinion a bit. just enough so theres still some traction against the tire but not too much as to shred my tire. haha. ah. im gonna give it a rolling start then power the esc
-mikey09120
06.01.2009, 01:18 AM
I would use some sort of rubber wheel instead of the pinion idea... Not sure where you can get that sort of thing with a set screw but I am sure it exists...
mikey09120
mikey09120's Avatar
06.01.2009, 01:22 AM
thats a good idea too... ive been looking around but hav yet to find one. ill keep searchig. maybe i can dip the pinion in plasti-dip or somethig too
-mikey09120
aqwut
aqwut's Avatar
06.01.2009, 01:24 AM
spring loaded rubber coated shaft, directly powered by an outrunner or the Revo tranny like you have... it would be awesome to see..
Metallover
Metallover's Avatar
06.01.2009, 01:27 AM
http://www.youtube.com/watch?v=Qxh_cMrIyVI
KMN
KMN's Avatar
06.01.2009, 02:37 AM
Nice use of masking tape for the battery mount.
Byte
06.01.2009, 09:05 AM
I'm also tinking to electrify my bike. But I've got a few questions:
- How to apply throttle if I use a Supersimple 100A ESC
- What to do with steering, how to disable it
Thanks
B4maz
06.01.2009, 10:53 AM
Matt Shumaker did this to a recumbent. http://www.recumbents.com/WISIL/shumaker/default.htm A ton of great information.
He sells a drive unit:
http://www.recumbents.com/WISIL/shumaker/edrive.htm
brushlessboy16
brushlessboy16's Avatar
06.01.2009, 11:27 AM
I have been thinking of this idea for a while, I think Using a cheap servo tester, and mount a lever on the potentiometer.
I also have one of these motors- already with a reduction box on it (50:1 iirc)
Should push a 20in bmx bike pretty decent on 6s.
  Send a message via Yahoo to brushlessboy16 Send a message via AIM to brushlessboy16 Send a message via MSN to brushlessboy16 Send a message via Skype™ to brushlessboy16
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
