RC Monster
high quality 48 pitch pinions
RUSTY XL-5
RUSTY XL-5's Avatar
high quality 48 pitch pinions - 04.27.2009, 11:31 PM
Were do I go to buy high quality 48 pitch (3mm) pinions? I'm looking for RC Mike quality but he doesn't sell any.
I will spank a nitro any day...guaranteed. :)
MetalMan
MetalMan's Avatar
04.28.2009, 12:22 AM
Do you mean hardened? Robinson pinions are as high-quality as they get for 48p.
RUSTY XL-5
RUSTY XL-5's Avatar
04.28.2009, 01:22 AM
I use theirs but they always have little "burrs" or "bumps" on the teeth. This makes them pretty noisy compared to my 28t traxxas pinion and not nearly as smooth. I was hoping that there was a brand that I hadn't heard of yet.
Semi Pro
Semi Pro's Avatar
04.28.2009, 04:39 AM
trinity zero g
best light weight 48p pinions money buys
you could also buy nylon robinson racing pinions, they are great too, and they last alot longer than you would think
chilledoutuk
04.28.2009, 08:51 AM
so what robinson racing pinions you been using then?
As i have used both the hard nickel coated ones and aluminium ones on my losi cars with losi gears and find them to be very quiet and mesh very nicely.
Maybe traxxas 48dp is not the same as most others 48dp i suppose you could try losi pinions i always found them to be of very high quality.
phildogg
phildogg's Avatar
04.28.2009, 08:54 AM
I've always used robinson racing pinions with no probs.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
SidewaysLS4
04.28.2009, 03:52 PM
Standard Robinson here, I like 'em
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
04.28.2009, 04:26 PM
I am running a VXL system in a Rustler with the stock traxxas 48p spur gear.
I have found that I burn through regular alloy Robinson pinions fairly quickly so that the one side of every tooth is flat. This makes the gears louder and the spur gear then wears out much quicker. I burnt through an aluminum 17t Robinson pinion in about 15 runs.
Traxxas pinions have held up very well.
The only pinion I have found to match it is the Robinson Racing "Absolute" pinion; I have at least 30 runs on the 16t and it looks like new. (Smaller pinions wear much faster because of the tooth profile and the fact that they have fewer teeth to go around).
http://www3.towerhobbies.com/cgi-bin...?&I=LXEX72&P=7
The timmy - Revo 3.3 MM 9XL 4s , Rustler MM 4600 3s
The ferty - Dual velineon Revo 3s, Rustler velineon 3s
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
