In Stock
jcflyer
In Stock - 04.11.2016, 04:52 PM
How do I find out if an item I want is in stock or not?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.11.2016, 10:32 PM
Aside from FLM parts, the site inventory is pretty accurate. RC-Monster branded parts are made in house and will usually show as in stock - a few days would be the longest lead time if you happened to order an RC-Monster item in between production runs.
jcflyer
04.11.2016, 10:44 PM
Hey Mike,
Thanks for replying, I am looking at the Baja Electric conversion kit for $169 but it doesn't say if it's in stock or not??? Also I sent you an email asking if the Poseiden 2028 motor would fit I gave you the measurements but you never got back to me... I am waiting to hear from you if the motor will fit before I buy the kit...
04.12.2016, 11:41 AM
It's the same diameter and only .3mm longer than the castle 2028 and hence It should fit fine.
It only used a 5mm shaft though so you will need a pinion adapter most likely.
jcflyer
04.12.2016, 12:09 PM
I am not sure what you mean by 5mm, the motor I am looking at uses an 8mm shaft. Are we talking about the same thing?
04.12.2016, 12:56 PM
All good I was reading their web site and stopped short of reading "except 2028 which has 8mm"
You should be fine and believe Mike keeps the kit in stock.
jcflyer
04.12.2016, 01:33 PM
Ok thanks brother!!!
RC Monster
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
