RC Monster
out of balance lipo
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
out of balance lipo - 08.08.2009, 02:14 PM
hey guys. i just recently bought two 3s 5000mah 30C Zippy Flightmax Lipos. i charged them when they came in and ran one of them in my brushless e-revo a bit. not even 5 minutes. and i put them away and a week later the voltages on one of my batteries read C1: 3.84 C2: 4.18 C3:4.19. is this normal? i am discharging it on my charger right now and im going to recharge and balance them
-mikey09120
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.08.2009, 02:48 PM
did you check the voltages when you charged them?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
wallot
wallot's Avatar
08.08.2009, 02:55 PM
for zippy yes it is normal sometimes. sometimes measurements are off as my volmeter was going crazy but LBA10 balanced the pack in less then 15 minutes.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
08.08.2009, 03:12 PM
I would charge them at a low rate, like .3 amp and balance at the same time. It will take a while but when the pack is fully charged, make sure it is in balance and then let it sit overnight. If one cell drops voltage quicker than the others, you have a weak cell. Not a big deal if you charge the pack then run it soon after, but always make sure your packs are in balance before you run them. You could also give it a light run (not alot of hard acell or braking and moderate speed for a few mins) then measure the voltages of the cells and see if one is lower than the others.
aqwut
aqwut's Avatar
08.08.2009, 03:59 PM
Or you could charge the cells one by one..
mikey09120
mikey09120's Avatar
08.08.2009, 04:17 PM
after charging the first time the voltages all read 4.20 and how do you charge the cells one at a time. this is my first lipo and im not confident enough to tear it down just yet
-mikey09120
08.08.2009, 04:31 PM
Originally Posted by mikey09120 View Post
...how do you charge the cells one at a time.
You'd have to connect to the proper cell in the balance tap. If you do this, you'll be limited to ~1.5A max because of the size of the wires and connector pins.
RC Monster
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
