I want to order a Hyperion Lipo but I have a traxxas charger. I've read somewhere that the balancing tabs are not compatible with the JST-XH Balance Harness. is there some type of adapter sold for my charger? I'm buying the HYPERION G3 VX 6500 MAH 5S 18.5V 35C/65C LIPOLY PACK
You can either install the xh plug onto the hyperion pack, or use an adapter in line(hyperion to xh plug). Either method would be pretty simple and inexpensive.
YOu can either install the xh plug onto the hyperion pack, or use an adapter in line(hyperion to xh plug). Either method wouldbe pretty simple and inexpensive.
MIke do you sell either the xh plug or the adapter? Link please if you do
Upon further review, the 5s Hyperion plug is actually directly compatible with the 5s jst-xh balance board(as is 4s and 6s). The pins and hole spacing align perfectly, though the xh receptacle doesn't have the clip catch. The Hyperion plug will fit right in and balance as it should without modification, though. :)
