Hi all, I know some of you run 1:10th cars as well as 1:8th so hopefully you can help me.
I have just found a 1:10th scale CRX mk2 bodyshell, and as I finally have a CRX mk2 now I couldn't resist it even though it was more expensive than my 1:8th bodyshell and has to be imported from the states.
Like the full size CRX it is tiny at 208mm wheelbase, which I will be taking slight liberties with and using a 210mm mini chassis rather than fabricating a chassis as I doubt 1mm on each wheelarch will be noticeable.
The obvious chassis choice would be a Tamiya M-03/M-05, but although I hear its a popular class elsewhere around the country it is not raced anywhere near me, which leaves me in a dilemma.
I could buy a Tamiya chassis anyway and have it as another basher, but I have 2 awesome 4wd on-road bashers already so I cant see it getting much use.
As it may not see much use I could save some money by buying the cheapest brokenest Tamiya chassis I can find on the bay with no electrics, buy a new set of wheels and tyres for it so it looks decent, and have myself a shelf queen which is quite tempting as one of the reasons I wanted it is to try out new paint schemes for a potential respray of my car and a static model will work fine for that and ensure the body stays in good nick.
There are a few belt drive 4wd Mini chassis available, not to popular here as only fwd is legal for Mini racing over here but it is pretty big in Japan apparently, if I went for one of these would it be legal for 1:10 touring or would it be ruled out by its shorter wheelbase? If not do you think a shorter car can be at all competitive? (I'm not bothered about getting in the A final, but if I'm always going to be last in the Z final I could see it getting wearing)
I could buy a 4wd mini chassis and set it up as a drifter, I have no local competitive drifting, and I have 2 on-road brushless beasts that can drift on rubber at high speed, but having a more typical hard tyred, low speed drifter would mean that I could open the door and run from the porch rather than walk down the road, and it would probably get more use than the Tamiya fwd chassis.
Has anyone tried racing a mini against a touring car? I know the 4wd chassis are faster than the 2wds so if you have and there wasn't much in it then it may be viable.
Is there a minimum weight on 1:10th touring cars?
Are touring car wheel/tyre sizes mandated? I think you can fit touring car wheels to Mini chassis
but Mini wheels are smaller with higher profile tyres, if I have to run touring wheels it will look like something from pimp my ride rolling on 22"s, rather than the sensible 15"s my car actually has.
