RC Monster
Car esc with RPM limiter?
whitrzac
Can't catch this...
whitrzac's Avatar
Car esc with RPM limiter? - 12.27.2013, 09:23 AM
Are there any car ESCs that have an adjustable RPM limit?
My theory: I can run a 3s and limit the overall RPM of a motor to ~60% of what the max would be, and it would have the same 'power' until the battery hits lipo cut....
Thus making the car more consistent over a 5-10min race.
Endpoint changes the RPM as the voltage drops.
Ideas?
nativepaul
nativepaul's Avatar
12.27.2013, 10:37 AM
Not that I know of but you could do the same thing by fitting a bigger 2s pack than you need, if it doesnt deplete fully you will have more volts at the end.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
whitrzac
Can't catch this...
whitrzac's Avatar
12.27.2013, 11:02 AM
It would lessen the issue, but I'm already running a 6000mah pack...
ta_man
12.28.2013, 09:46 AM
You can now get 8000 to 10000 2S packs.
Alternatively, choose a motor that has a peak RPM that is about 60% of your current peak RPM. Being lower KV, it will draw less current and give you the same effect. Example: I ran a 8.5 turn 550 motor on 3S instead of a 4.5/5.5 motor on 2S. The motor barely got warm and the rather small 3S pack (3400 mAHr) would only be drained about 50% in a 10 minute race. Now you can get 3S packs with 4300 mAHr capacity that are the same size as the standard 2S packs.
12.28.2013, 03:18 PM
Lower kv rating motor seems like a no-brainer to me; exactly the same effect as lowering the max rpm whilst maintaining the power output ( based on the same size motor, though lower kv version will have more torque so it's win-win ) and reducing current draw & temps.
RC Monster
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
